Microsoft Basic Optical Wired Mouse (White)
Clearance!
Clearance
Price Drop
Quicklinx: CSRRWS00 Mfr#: P58-00058
Wired / Wireless: Wired
Colour: White
Compatibility: Mac, PC
46 in stock
£7.07 ex VAT
£8.48 inc VAT
Benefit from great features such as ambidextrous design and stay at your peak creativity without emptying your wallet. With this mouse, you can rely on optical technology for smooth, precise control. Use the scroll wheel for quick, confident navigation, and customizable buttons for one-click access to your favorite documents, music files or functions.
Comfort and Precise Control
Benefit from great features such as ambidextrous design and stay at your peak creativity without emptying your wallet. With this mouse, you can rely on optical technology for smooth, precise control. Use the scroll wheel for quick, confident navigation and customizable buttons for one-click access to your favorite documents, music files, or functions.
  • Optical technology
    Navigate with better speed, accuracy and reliability. The optical sensor tracks movement on nearly any surface.
  • Scroll even faster
    Move through your documents quickly without having to use the on-screen scroll bar.
  • Comfortable in either hand
    Use your mouse with your left or right hand. Ambidextrous design makes it comfortable either way.
  • Customizable buttons
    Get quick access to the media, programs and files you use most often.
  • Device stage
    Quickly and easily access common tasks, including product information, registration, settings and more for popular devices such as mobile phones, cameras and printers, and mouse, keyboard and webcam products.
  • Ergonomic design
    Point and click in comfort. Ergonomic design helps you work longer without discomfort.
Microsoft Basic Optical Mouse - mouse - USB - white
Mouse
Wired - USB
White
Orientation
Right and left-handed
5.6 cm x 11.1 cm x 3.7 cm
95 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Performance
3000 fps
Programmable buttons, scrolling wheel
1 x USB cable - integrated - 1.7 m
Apple MacOS X 10.1.5 or later, Microsoft Windows 98/2000/XP/Vista/7
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Orientation
5.6 cm
11.1 cm
3.7 cm
95 g
White
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Performance
3000 fps
1 x USB - 4 pin USB Type A
Limited warranty - 3 years
-10 °C
5 - 80% (non-condensing)
Colour: White
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 0 - 50
