Microsoft Basic Optical Mouse for Business PS2/USB White
Quicklinx: C47KWS00 Mfr#: 4YH-00008
Wired / Wireless: Wired
Colour: White
Compatibility: Mac, PC
40 in stock
£6.34 ex VAT
£7.60 inc VAT
Navigate quickly and easily with the convenient scroll wheel and work on virtually any surface. Get one-click access to frequently-used features with customizable buttons.
  • Optical technology
    Navigate with better speed, accuracy and reliability - the optical sensor tracks movement on nearly any surface without the hassle of clogged mouse parts.
  • Scroll even faster
    Move through your documents quickly without having to click on the scroll bar.
  • Comfortable in either hand
    Use your mouse with your left or right hand - ambidextrous design makes it comfortable either way.
  • Customizable buttons
    Get quick access to the media, programs, and files you use most often with customizable buttons.
  • Device stage
    Quickly and easily access common tasks, including product information, registration, settings and more for popular devices such as cell phones, cameras, printers, and mouse, keyboard and webcam products.
  • Ergonomic design
    Point and click in comfort - ergonomic design helps you work longer without discomfort.
Microsoft Basic Optical Mouse for Business - mouse - PS/2, USB - white
Mouse
Wired - PS/2, USB
White
Orientation
Right and left-handed
5.8 cm x 11.3 cm x 3.9 cm
117 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Performance
3000 fps, up to 20 inches per second
Programmable buttons, scrolling wheel
1 x USB cable - integrated - 1.8 m , 1 x mouse adapter - external
Microsoft Windows 98/2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Tablet PC Edition, Microsoft Windows XP Media Center Edition, Microsoft Windows Vista, Apple MacOS X 10.1 - 10.4.x
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Orientation
5.8 cm
11.3 cm
3.9 cm
117 g
White
Input Device
Wired
PS/2, USB
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Performance
1 x USB - 4 pin USB Type A , 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
UL, VCCI, BSMI, GOST, cUL, ICES-003, CB, MIC, FCC, WEEE, REACH
Limited warranty - 3 years
-10 °C
5 - 80% (non-condensing)
Colour: White
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 0 - 50
