Microsoft Basic Optical Mouse - Black
Quicklinx: 91M8WS00 Mfr#: P58-00057
Type: Mouse
Wired / Wireless: Wired
Colour: Black
Compatibility: Mac, PC
More than 50 in stock
£8.76 ex VAT
£10.51 inc VAT
Microsoft Optical Technology replaces the old-fashioned mouse ball and works on virtually any surface. Easy and comfortable to use, Basic Optical Mouse is a good choice for value.
Now you can experience the benefits of the world's most powerful optical technology. The Microsoft optical sensor replaces your old-fashioned mouse ball. The ambidextrous design is comfortable whether you mouse with your left or right hand.
Microsoft Basic Optical Mouse - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
5.6 cm x 11.1 cm x 3.7 cm
95 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Performance
3000 fps
Programmable buttons, scrolling wheel
1 x USB cable - integrated - 1.7 m
Apple MacOS X 10.1.5 or later, Microsoft Windows 98/2000/XP/Vista/7
Microsoft Certification
Compatible with Windows 7
3 years warranty
Mouse
Orientation
5.6 cm
11.1 cm
3.7 cm
95 g
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Performance
3000 fps
1 x USB - 4 pin USB Type A
Limited warranty - 3 years
-10 °C
5 - 80% (non-condensing)
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 0 - 50
