Microsoft Optical Technology replaces the old-fashioned mouse ball and works on virtually any surface. Easy and comfortable to use, Basic Optical Mouse is a good choice for value.
Now you can experience the benefits of the world's most powerful optical technology. The Microsoft optical sensor replaces your old-fashioned mouse ball. The ambidextrous design is comfortable whether you mouse with your left or right hand.
- Microsoft Basic Optical Mouse - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- Orientation
- Right and left-handed
- 5.6 cm x 11.1 cm x 3.7 cm
- 95 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 800 dpi
- Performance
- 3000 fps
- Programmable buttons, scrolling wheel
- Cables Included
- 1 x USB cable - integrated - 1.7 m
- OS Required
- Apple MacOS X 10.1.5 or later, Microsoft Windows 98/2000/XP/Vista/7
- Microsoft Certification
- Compatible with Windows 7
- 3 years warranty
- Mouse
- Orientation
- 5.6 cm
- 11.1 cm
- 3.7 cm
- 95 g
- Black
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 800 dpi
- Performance
- 3000 fps
- 1 x USB - 4 pin USB Type A
- Cables Included
- OS Required
- Limited warranty - 3 years
- -10 °C
- 40 °C
- 5 - 80% (non-condensing)
