Microsoft Arc Touch Mouse Surface Edition
Quicklinx: BYPGWS00 Mfr#: P9X-00003
Experience the Arc Touch Mouse: there is no equal in look, feel, and performance. With a dramatic design and easy elegance, this stylish mouse is a perfect fit for your lifestyle. Flick to zip down the page. Tap to stay at your destination. Feel the speed and responsiveness to your touch.
  • Perfectly portable
    Stylish and eye-grabbing, Arc Touch Mouse is more than a pretty device. It's reliable wireless freedom plus Microsoft touch technology, on the go. Use it just about anywhere, even on a rough wood surface or carpet, thanks to BlueTrack Technology does not work on clear glass or mirrored surfaces. Plus you can retain wireless control of your computer up to 15 feet away.
  • Curve it for use, flatten for storage
    Arc Touch Mouse's innovative design allows for quick use and storage. Curve it comfortably to get started. Then smoothly glide your finger up or down the touch strip. When you're done, keep the tiny transceiver plugged into your computer's USB port, or attach it magnetically onto the underside of the mouse. Then flatten Arc Touch Mouse to turn it off, and slip it into your pocket or bag as easily as a cell phone.
  • Precise vertical scrolling by feel, not wheel
    The Touch strip on the Arc Touch Mouse responds precisely to the speed of your finger movement, using Haptic feedback (light vibration that signals scrolling speed) to scan through documents or web pages as quickly - or as cautiously - as needed, entirely by feel.
Microsoft Arc Touch Mouse - Surface Edition - mouse - Bluetooth - dark titanium
Mouse
Wireless - Bluetooth
Dark titanium
Orientation
Right and left-handed
5.7 cm x 13 cm x 1.45 cm
81.9 g
Movement Detection Technology
Optical
Touch-sensitive scroll, on/off power switch, Microsoft BlueTrack Technology
AAA type
3-year warranty
Surface Pro 4
Mouse
Orientation
5.7 cm
13 cm
1.45 cm
81.9 g
Dark titanium
Input Device
Wireless
Bluetooth
Optical
2 AAA batteries
AAA type
Alkaline
Limited warranty - 3 years
Microsoft Surface Pro 4
