Microsoft Arc Touch Mouse (Black)
Quicklinx: 8DN5WS00 Mfr#: RVF-00050
Experience the Arc Touch Mouse: there is no equal in look, feel, and performance. With a dramatic design and easy elegance, this stylish mouse is a perfect fit for your lifestyle. Flick to zip down the page. Tap to stay at your destination. Feel the speed and responsiveness to your touch.
  • Flexible design
    Curve for comfort, flatten to pack. It is perfect fit for your hand - and your mobile lifestyle.
  • Power on and off
    Curve to turn on. Flatten to turn off. No button to switch. A green light flashes to show the battery is working, and then turns off to save battery life.
  • BlueTrack Technology
    It works on difficult surfaces - rough glossy, or soft.
  • 2.4 GHz - 30-foot wireless range
    The 2.4 GHz wireless USB nano transceiver connects wirelessly right out of the box with virtually no interference and has up to a 30-foot wireless range.
  • Snap-in transceiver
    Nano transceiver snaps into the bottom of the mouse.
  • Comfort for either hand
    Use your mouse with your left or right hand.
  • Device stage
    Quickly and easily access common tasks, including product information, registration, and settings.
Microsoft Arc Touch Mouse - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
5.88 cm x 13 cm x 1.5 cm
88 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
2
Movement Resolution
1000 dpi
Performance
8000 fps, up to 72 inches per second
Touch-sensitive scroll, on/off power switch, Microsoft BlueTrack Technology, Nano wireless receiver
2 x AAA type
Microsoft Windows Vista / XP / 7
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
Orientation
5.88 cm
13 cm
1.5 cm
88 g
Input Device
Wireless
2.4 GHz
Optical
Buttons Qty
2
Movement Resolution
1000 dpi
Performance
1 x USB - 4 pin USB Type A
USB 2.0
AAA type
Alkaline
Installed Qty
2
Run Time (Up To)
6 months
Limited warranty - 3 years
5 - 80% (non-condensing)
