Microsoft made their award-winning design of Arc Touch Mouse even better for those on the go. They have added Bluetooth 4.0 Low Energy. A clutter-free and reliable experience that works from up to 30 feet away. Utilizing the latest in Bluetooth technology, consuming less power.
And just like the original, the Arc Touch Bluetooth Mouse curves to turn on and flattens to turn off. Comfortable and portable, shaped to match the natural curve of your hand, it’s a perfect fit for your mobile lifestyle. The touch strip responds precisely to the speed of your finger movement, using haptic feedback to scroll vertically.
Take advantage of BlueTrack Technology, which combines the power of optical with the precision of laser for remarkable tracking on virtually any surface. Even use it on a rough wood surface or carpet, with BlueTrack Technology.
Perfectly portable
Stylish and eye-grabbing, Arc Touch Mouse is more than a pretty device. It's reliable wireless freedom plus Microsoft touch technology, on the go. Use it just about anywhere, even on a rough wood surface or carpet, thanks to BlueTrack technology. -
Curve it for use, flatten for storage
Arc Touch Mouse's innovative design allows for quick use and storage. Curve it comfortably to get started. Then smoothly glide your finger up or down the touch strip. When you're done, keep the tiny transceiver plugged into your computer's USB port, or attach it magnetically onto the underside of the mouse. Then flatten Arc Touch Mouse to turn it off, and slip it into your pocket or bag as easily as a cell phone. -
Precise vertical scrolling by feel, not wheel
The Touch strip on the Arc Touch Mouse responds precisely to the speed of your finger movement, using Haptic feedback (light vibration that signals scrolling speed) to scan through documents or web pages as quickly - or as cautiously - as needed, entirely by feel.
- Microsoft Arc Touch Bluetooth Mouse - mouse - Bluetooth 4.0 - grey
- Mouse
- Connectivity Technology
- Wireless - Bluetooth 4.0
- Grey
- Orientation
- Right and left-handed
- 5.88 cm x 13 cm x 3.65 cm
- 81.9 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Performance
- Up to 30 inches per second, 1200 fps
- Touch-sensitive scroll, Microsoft BlueTrack Technology
- Battery
- AAA type
- OS Required
- Windows 8, Windows 8.1, Microsoft Windows RT 8.1, Microsoft Windows RT 8
- 3-year warranty
- Mouse
- Orientation
- 5.88 cm
- 13 cm
- 3.65 cm
- 81.9 g
- Grey
Input Device
- Wireless
- Interface
- Bluetooth 4.0
- Max Operating Distance
- Up to 20 m
- Optical
- Buttons Qty
- 3
- 1000 dpi
- Performance
- Included Accessories
- 2 AAA batteries
- UL, VCCI, ISO 9001, GOST, cUL, ISO 14001, CB, EMC, FCC, R&TTE, KCC, WEEE, REACH, NCC, iDA
- AAA type
- Technology
- Alkaline
- Run Time (Up To)
- 6 months
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 80% (non-condensing)
