Microlab H30BT incorporates the latest Bluetooth wireless technology. Its beautiful bookshelf speaker design will compliment your desktop. It combines Bluetooth 4.0 technology, NFC fast pairing function and the professional speaker drivers together, and aims to produce natural and comfortable sound.
Elegant and precise cabinet construction technology
H30BT is made from hi-quality wooden materials. The milk white color is designed to fit your home home decoration. The silver arch tray ireduces the sound resonance. The hi-efficiency speaker fins are built-in to ensures the speaker creates awe-inspiring sound and exhilarating effects. It is ideal for digital devices such as TV, CD/DVD, notebook, PC etc to enjoy your music.
Bass reflex port design of both speakers cabinets provide deeper bass effects. The classic bookshelf stereo speaker arrangement creates dynamic sound movements for realistic effects
Wireless music technology
H30BT features the newest Bluetooth 4.0 technology, A2DP and NFC pairing system, which aims to simplify your music control experience. Now you can enjoy your music more easily with any of your Bluetooth media devices and quick pairing to H30BT through the NFC fast pairing system.
NFC( near field communication)
This function allows any NFC enabled device to connect to the speaker system easily with only one press.
1. To use NFC, just tap the Smartphone or NFC enabled device on the NFC logo at the top of the right speaker.
2. This will connect the system to this device and disconnect any previous connected device.
Premium sound performance
H30BT uses the analog amplifier designing concept that help to reproduce the sound to the hi-fi level. The special designed woofer carries the bass reflex port, that provides the rich and smooth bass performance and the precise crafted tweeter produces clean and natural treble. H30BT can provide up to 24 watt sound output that is enough for enjoying your favorite movies and soundtracks in your personal listening environments, such as study rooms, bedroom and small-medium living space.
Features:
- Quality bookshelf stereo speaker system with built-in amplifier
- NFC standards to quickly connect the speakers to NFC enabled wireless devices
- Bluetooth stereo audio using A2DP for wireless music streaming
- A level of versatility stereo speaker
- Noise cancelling with excellent sound, ideal for your favorite entertainment digital playbacks
- Bass reflex design for efficient woofer performances
- NFC function to connect your media devices freely
- Microlab H 30BT - speakers - for PC - wireless
- Product Type
- Speakers - for PC
- System Components
- 2 speakers
- Speaker Type
- 2-way - active
- Nominal Output Power (Total)
- 24 Watt
- Frequency Response
- 50 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth, NFC
- Speaker System Details
- 2 x speaker 12 Watt - 50 - 20000 Hz
- Speaker Details
- Speaker - 12 Watt - at 1 kHz - 0.5% THD - 2-way - active
- White
- 13.5 cm x 22 cm x 22.5 cm
- 43 kg
- Product Type
- Speakers - for PC
- Enclosure Colour
- White
- Enclosure Material
- MDF
Speaker System
- System Components
- 2 speakers
- Speaker Type
- 2-way - active
- Audio System Continuous Power (Total)
- 24 Watt
- 50 - 20000 Hz
- Signal-To-Noise Ratio
- 75 dB
- Amplifier
- Integrated
- Bluetooth 4.0, Near Field Communication (NFC)
- Controls
- Power on/off, volume, treble, bass
- Detachable Grilles
- Speakers Included
- 2 x speaker - 2-way - 12 Watt - 50 - 20000 Hz
- Speaker Details
- Speaker - 12 Watt - at 1 kHz CFR - 0.5% THD - 2-way - active
- Driver Details
- Speaker: woofer driver - 3.5" , Speaker: tweeter driver - 0.75"
- Connector Type
- Audio line-in (RCA x 2) , Audio line-out (RCA)
- Power Source
- AC power adapter
- 13.5 cm
- 22 cm
- 22.5 cm
- 43 kg
