Meraki MV71 Cloud Managed Outdoor HD Dome Camera
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVQS
Quicklinx: DV94WS00 Mfr#: MV71-HW
£805.66 ex VAT
£966.79 inc VAT
The MV family brings Meraki magic to the video security world. Impossibly simple to deploy, configure, and manage, both the MV21 and MV71 provide reliable security at any scale. MV71 features IP66 weather-resistance and IK10 vandal-resistance ratings, making it ideal for demanding environments.
By utilizing industrial grade, high write endurance solid state storage on each camera, the MV family has removed the NVR from the equation. Video records to the camera itself rather than relying on an external recording solution. The Meraki dashboard will automatically detect whether the viewing computer is in the local network or somewhere remote. Local streaming video never goes to the cloud, saving WAN bandwidth, while remote streaming video is proxied through the cloud, allowing it to be viewed from anywhere.
Laptop gone missing? Retroactively select the desk or conference table where it was last seen and the dashboard returns a list of motion events that can help lead to its recovery. Select important video segments and export from the dashboard to a shareable and downloadable link. With granular access controls, decide who has access to historical footage and exporting privileges. Easily search historical footage using natural language processing and go from identifying an event to sharing it in just a couple of clicks.
MV cameras come with everything needed for a successful deployment in the box. Add cameras to a network before they even arrive, and adjust focus, aperture, and zoom settings remotely. The Meraki dashboard's elegant interface allows for remote management, the way it should be.
Cisco Meraki MV71 - network surveillance camera - dome
Network surveillance camera - fixed - dome - outdoor - vandal / weatherproof
17.3 cm x 17.3 cm x 11.5 cm
1.48 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
3.3 x
Max Resolution
1280 x 720
Frame Rate (max)
30 frames per second
Video Modes
720p
Optical Sensor Type
CMOS - 1/3.2" - 0.5 MP
Minimum Illumination
0.27 lux - colour - F1.3 , 0.001 lux - B&W - F1.3
Focal Length Control
Vari-focal
Focal Length
3 mm - 10 mm
Lens Iris
F/1.3-2.5 - auto iris
Panning Range (degree)
350
Tilting Range (degree)
65
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Heater
3-year warranty
Environmental Parameters (operating)
-40 °C - 50 °C
Dome
Wired
17.3 cm
17.3 cm
11.5 cm
1.48 kg
Camera
Colour - Day&Night - fixed - outdoor - vandal / weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
1280 x 720
Video Modes
720p
Exposure Range
1/5 sec - 1/32000 sec
Infrared LEDs
Infrared Distance
30 m
Digital Video Capture Resolution
1280 x 720
Frame Rate (max)
Heater
Image Sensor
0.5 MP CMOS 1/3.2"
Lens Construction
Vari-focal
Optical Zoom
3.3 x
Focal Length
3 mm - 10 mm
Lens Iris
F/1.3-2.5 auto iris
Panning
Range (degree)
350
Tilting
Range (degree)
65
Network Interface
Ports
LAN/power - RJ-45
Ceiling mount kits, wall mount kit
IK10, IP66
Power Requirements
PoE
21.95 Watt
Limited warranty - advance parts replacement - 3 years
-40 °C
50 °C
Brand: Meraki
Price Range Ex VAT: £750 - £1000
