The Cisco Meraki MR33 is an entry-level, four radio, cloud-managed 2x2 MU-MIMO 802.11ac Wave 2 access point. Designed for next-generation deployments in offices, schools, hospitals, shops, and hotels, the MR33 provides performance, security, and simple management.
A dedicated third radio provides real-time WIDS/ WIPS with automated RF optimization. In addition, an integrated fourth radio delivers Bluetooth Low Energy (BLE) scanning and beaconing functionality. The MR33 is 100% cloud-managed via the intuitive, browser-based Meraki Dashboard, and includes a rich, out-of-the-box feature set without additional cost or complexity.
Efficient connectivity
The MR33 Cloud Managed offers seamless integration with 802.11a/b/g/n/ac Wave 2 standards, ensuring broad compatibility and high-speed connectivity. Its support for both 2.4 GHz and 5 GHz Wi-Fi bands allows for flexible deployment in diverse network environments. -
Enhanced security
Equipped with a comprehensive suite of encryption algorithms including AES, TKIP, TLS, TTLS, WEP, WPA, WPA2-Enterprise, and WPA2-PSK, this device provides robust security measures to protect sensitive data and maintain a secure wireless network. -
Advanced performance features
Features such as MU-MIMO and SU-MIMO technology, beamforming technology, and traffic shaping enhance the device's performance by improving signal strength, managing bandwidth efficiently, and ensuring optimal data throughput for a superior user experience. -
Easy installation
Designed to be both ceiling and wall-mountable, the MR33 Cloud Managed offers flexible installation options to fit various spatial requirements, making it an ideal choice for businesses looking to deploy a versatile and effective wireless solution. -
Power efficiency
With Power over Ethernet (PoE) support and a modest power consumption of 11 W, this device is engineered for energy efficiency, reducing operational costs while delivering reliable wireless connectivity.
- Cisco Meraki MR33 Cloud Managed - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
- Frequency Band
- 2.4 GHz, 5 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- DC 12 V
- 21.5 cm x 11 cm x 3.2 cm
- 376.5 g
- Limited lifetime warranty
- 21.5 cm
- 11 cm
- 3.2 cm
- 376.5 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1.3 Gbps
- Line Coding Format
- 256 QAM
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Power, Boot State, status
- Traffic shaping, wall mountable, Wireless Intrusion Detection System (WIDS), Wi-Fi Multimedia (WMM) support, Maximum Ratio Combining (MRC), ceiling mountable, Wireless Intrusion Prevention System (WIPS), tagged VLAN, security lock slot (cable lock sold separately), 802.1x authentication, DiffServ Code Point (DSCP) support, MU-MIMO technology, Bluetooth Low Energy Beaconing, Unscheduled Automatic Power Save Delivery (U-APSD), beamforming technology, SU-MIMO technology
- Encryption Algorithm
- AES, TLS, TTLS, TKIP, WPA, WPA2-PSK, WPA2-Enterprise, WEP
- Authentication Method
- Extensible Authentication Protocol (EAP), EAP-SIM
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac, IEEE 802.11r
Aerial
- Antenna
- Internal
- Directivity
- Omni-directional
- 1 x 1000Base-T (PoE) - RJ-45
- CSA, IC, FCC, RoHS, RCM
- PoE
- Voltage Required
- DC 12 V
- 11 Watt
- Limited warranty - advance hardware replacement - lifetime
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
