Meraki GO Indoor WiFi Access Point
Quicklinx: DVNDWS00 Mfr#: GR10-HW-UK
  • IEEE 802.11n
£62.77 ex VAT
£75.32 inc VAT
Meraki Go is WiFi built for businesses. With Meraki Go, you can easily add multiple WiFi networks so that staff, guests, and point-of-sale devices can share a single internet connection. Set up blocked websites to secure your network, and easily limit usage of certain applications to prioritize your business-critical applications. Each Indoor and Outdoor Access Point requires an active Go subscription, which provides a 1-year hardware warranty, security updates, and in-app support. Within the Meraki Go smartphone app, setup is quick and troubleshooting is easy with Guided Setup and Network Alerts.
  • QUICK & EASY SETUP
    Get your network up and running in minutes. Simple, yet powerful management from anywhere using the Meraki Go mobile app or web portal
  • SECURE & RELIABLE
    Business-grade security that blocks malicious websites, malware, phishing, and other harmful threats. Stay connected and productive with devices powered by Cisco
  • FEATURES FOR BUSINESS
    Create guest WiFi with a tap, a custom splash page in seconds, or use guest insights to better engage with customers. Remote visibility, troubleshooting tools, and alerts
  • NO FEES OR LICENSES
    With no required subscription or license, you'll get automatic updates, mobile app management, and tech support included
  • GROWS WITH YOU
    Easily add access points as your business' coverage needs grow and simply manage from one place; desktop or wall mountable; mesh-ready
Cisco Meraki Go GR10 - radio access point - Wi-Fi 5, Wi-Fi 5
Radio access point
Wall mountable - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Mounting screws, wall mounting kit
Power Over Ethernet (PoE) Supported
PoE
DC 12 V / DC 37 - 57 V (PoE)
20.2 cm x 12.3 cm x 2.6 cm
1-week warranty
Radio access point
Ruggedized Design
Indoor
20.2 cm
12.3 cm
2.6 cm
Wall mountable
Wireless
Line Coding Format
256 QAM
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, Boot State, status
Maximum Ratio Combining (MRC), beamforming technology, SU-MIMO technology, PMK Caching, 2x2 MU-MIMO technology, layer 3 roaming, opportunistic key caching (OKC), packet aggregation
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.11r, IEEE 802.11ac Wave 2
Aerial
Antenna
Internal
Antenna Qty
2
Directivity
Omni-directional
1 x 1000Base-T (PoE) - RJ-45
1 x network cable
RoHS, EN 60601-1-2, Directive 93/42/EEC
PoE
11 Watt
Limited warranty - 1 year
5 - 95% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Protocol: IEEE 802.11g
Protocol: IEEE 802.11a
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac Wave 2
Protocol: IEEE 802.11b
Brand: Meraki GO
