Meraki Go's cloud-based switches are specially designed with small business owners in mind. Create a complete app-managed network solution to increase business productivity and customer engagement, with minimal time, resources, and expertise.
Get up and running in less than 5 minutes, with no technical knowledge needed. The Meraki Go app will guide you through each step of connecting and configuring your network.
See what devices are connected to which ports without having to physically follow cables, troubleshoot problems using live tools built into the app, for example cable testing, and increase security by disabling unused ports.
Your hardware will be automatically kept up to date with the latest firmware, meaning you don't have to worry about your critical business data being exposed to hackers or ransomware attacks.
- Cisco Meraki Go GS110-48 - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 2 x SFP (mini-GBIC) (uplink)
- Performance
- Switching capacity: 104 Gbps
- Fanless, cloud managed
- Localisation
- United Kingdom
- 1-year warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- 48 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP uplink , 1 x management RJ-45
- Localisation
- United Kingdom
- Limited warranty - 1 year
