The Maxtor M3 portable external hard drive delivers handy portable storage. It is easy to take wherever you go, and has ample capacity. The durable black design stands up to the rigors of daily use.
What's in the box?
- 1 x Maxtor M3 2Tb
- USB 3.0 cable
- Multi-language manual
- Maxtor D3 Station STSHX-D201TDBM - hard drive - 2 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 2 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- SafetyKey, automatic backup, NTFS formatted, LED status indicator
- Power Source
- Included AC adapter
- Enclosure Colour
- Durable black
- 12.92 cm x 18.06 cm x 4.7 cm
- 743 g
- 3-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.0
- 12.92 cm
- 18.06 cm
- 4.7 cm
- 743 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- Power Device
- Power adapter
- Software Included
- Secure Drive, SecretZone
- OS Required
- Apple MacOS X 10.4.8 or later, Microsoft Windows Vista / 7 / 8 / 10
- Cables Included
- 1 x USB 3.0 cable - external
- TUV, C-Tick, BSMI, NEMKO, FCC, IRAM, EAC, China RoHS
- Enclosure Colour
- Durable black
- Limited warranty - 3 years
- 5 °C
- 40 °C
