Manta 42" 3D 1080P LCD TV
Quicklinx: 7WRYWS00 Mfr#: LCD4214
  • FREEVIEW
  • 1080p
  • DVB-T
The Manta 42-inch Passive 3D Widescreen LCD TV supplied with 4 Sets of 3D Glasses (1 are clip-on) brings you the experience of 3D Cinema in your own home.
Connect to either a 3D Blu Ray Player,3D Games Console,Sky+ or Virgin HD+ 3D device to enjoy the full experience of 3D TV (sold separately).
The Manta 42-inch also features 2D to 3D conversion to deliver a pseudo 3D experience via standard Freeview Digital TV or DVD/ Blu Ray. The Manta 42-inch is Full HD1080P compatible ideal for getting the best out of a High Definition Blu Ray player, Full HD games console or other HD device.
Features up to 50 digital Freeview channels & up to 24 radio stations without the need for subscription.
The Manta LCD TV range features a PC input which enables you to connect your PC & use as a PC monitor.
The Manta 42-inch is VESA wall mounting compatible.
This LCD TV features built-in USB Playback facility which enables you to play compatible Photo's, Music & Video (including 3D) content saved onto an external USB Stick (sold separately).
Manta TV's come with a Power Supply Switch for safe power cut-off to save energy.
Manta LCD TV's feature easily accessible side connections for USB,Headphone,S-Video & AV Inputs.
Box Contains
Manta LCD4214 42" 3D LCD TV, 4 Pairs of Passive 3D Glasses (1 are clip-on), TV Stand, Remote Control & Batteries, Instructions
Model
LCDTV4214
HD Standard
1080p (FullHD)
Display / Diagonal Size
42 in
Television / Type
3D LCD TV
LCD
Display / 3D Technology
Native Resolution
1,920 x 1,080
Aspect Ratio
16:9
Video Input / Analogue Video Format
PAL
Freeview Bult In
Freeview
TV Tuner / Type
DVB-T
Tuner Type
1x digital
HDMI Inputs
2
SCART, Composite, Component, S-Video
Contrast Ratio
15,000:1
Dimensions & Weight / Depth
115 mm
Dimensions & Weight / Height
625 mm
Dimensions & Weight / Width
1014 mm
Television / Diagonal Size (cm)
106.7 cm
Audio System / Speaker System
2 speakers
Dimensions & Weight (Shipping) / Shipping Weight
22 kg
Display / Image Aspect Ratio
16:9
Display / Image Contrast Ratio
15,000:1
Display / Interface
VGA (HD-15)
Display / Widescreen
Widescreen
Memory Card Reader / USB Port
Memory Card Reader / USB Ports Qty
1
Network & Internet Multimedia / Connectivity Protocols
USB
Network & Internet Multimedia / Functionality
Digital video playback
Stands & Mounts / Stand Included
Video Input / Analogue video Signal
Scart
TV Tuner / Tuner Qty
1
Digital TV Tuner / Digital TV Tuner Type
DVB-T
TV Tuner / Conditional Access
Common Interface (CI) slot
