The Manhattan MondoHub features a high-capacity 4-amp power adapter with enough ports to manage a growing collection of USB-enabled devices. Unlike some other large capacity USB Hubs available on the market, the MondoHub features 4 SuperSpeed USB ports and can recharge devices or transfer data at lightning fast speeds.
The compact and durable case features the power and hub-to-PC ports on the side panel to help better organize connections and minimize cable clutter. This high-quality USB Hub also features automatic overcurrent protection for each port and hot-swapping Plug and Play connection. With a power switch for each port, the MondoHub gives users complete control over which devices are using power or valuable system resources.
- Manhattan MondoHub - hub - 28 ports
- Hub - 28 ports
- Subtype
- USB
- Ports
- 24 x USB 2.0 + 4 x SuperSpeed USB
- USB powered
- USB 1.1, USB 2.0, USB 3.0
- Power
- AC 100/230 V (50/60 Hz)
- 22.9 cm x 11.2 cm x 2.3 cm
- 354 g
- Black
- System Requirements
- Apple MacOS X 10.0 or later, Microsoft Windows 2000/XP/Vista/7
- Limited lifetime warranty
- Hub - 28 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- USB powered
- 24 x USB 2.0 Type A , 4 x USB 3.0 Type A
- Power Device
- External power adapter
- Voltage Required
- Black
- Cables Included
- 1 x USB cable - 0.8 m
- Plug and Play, FCC, WEEE
- OS Required
- 22.9 cm
- 11.2 cm
- 2.3 cm
- 354 g
- Limited warranty - lifetime
