Manhattan Projector Ceiling Mount
Quicklinx: C0NKWS00 Mfr#: 424868
£61.99 ex VAT
£74.38 inc VAT
Easily put a projector in place and keep it in prime position. Manhattan Universal Projector Ceiling Mounts hold projectors stable and steady with precise tilt, 360° swivel and height adjustments that keep images clear, sharp and defined. Constructed of lightweight, quality aluminum materials, Manhattan Universal Projector Ceiling Mounts fit a range of models with a secure, confident and balanced overhead installation. The ceiling plate fits a range of ceiling slopes. Internal cable management helps conceal unsightly cords and connections for a professional, finished appearance. Ideal for home theater, auditorium, office, retail, classroom, video conferencing and other commercial applications, Manhattan Universal Projector Ceiling Mounts help focus attention where it matters most.
Manhattan Universal Projector Ceiling Mount - ceiling mount
Ceiling mount
Adjustable Height
122-202 cm
Adjustments
Tilt
5.8 kg
Recommended Use
Projector
Max Load Weight
15 kg
Material
Steel
Silver
Adjustable Height
122-202 cm
5.8 kg
Material
Steel
Silver
AV Furniture
Ceiling mount
Mounting Components
Ceiling mount
Recommended Use
Projector
Cable Management
Cable Management System (CMS)
Adjustments
Tilt
Max Load Weight
15 kg
Adjustable height, swivel adjustment
Limited warranty - lifetime
