The Manhattan LCD monitor pole with double-link swing arm provides a secure and elevated position for two flat-screen monitors to help free up valuable desk and work space. Its fully adjustable tilt, rotate, side-to-side, height and tension settings enable a comfortable and productive viewing position that helps reduce eye fatigue and neck and back strain. LCD monitors can be easily rotated around the pole to allow others to view presentations and other multimedia displays from almost any direction.
Durable die-cast aluminum construction and a sturdy clamp provide a quick, easy and secure mount to a desktop or other horizontal surface. VESA compliant and ready to install with included hardware, there's no need to drill holes into desks or countertops.
- Manhattan - mounting kit
- Product Type
- Mounting kit
- Mounting Components
- Desk clamp mount, mounting pole, double swing arm, screws
- 41.3 cm
- Adjustments
- Tilt
- 4.6 kg
- Recommended Use
- 2 LCD displays
- Recommended Display Size
- 13"-24"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 12 kg
- Material
- Aluminium
- Black
- Limited lifetime warranty
- 41.3 cm
- 4.6 kg
- Material
- Aluminium
- Black
AV Furniture
- Mounting kit
- Recommended Use
- 2 LCD displays
- 13"-24"
- Adjustments
- Tilt
- Max Load Weight
- 12 kg
- Adjustable height, rotating
- Limited warranty - lifetime
