PCI Express Balances Cost, Performance, Compatibility and Advanced Features for Computing Platforms The MANHATTAN Serial PCI Express Card quickly and easily adds one DB9 port to PCI Express-enabled desktop systems to connect and communicate with serial peripheral devices.
Fast Data Transfer
The MANHATTAN Serial PCI Express Card can be configured to achieve baud rates of up to 230,400 bps to take advantage of PCI Express data transfer speeds of up to 2.5 Gbps. Compliance with PCI Express 1.1 specifications ensures that most PCI ExpressCard-equipped desktop computers and devices can operate at peak performance.
Simple Installation
The MANHATTAN Serial PCI Express Card fits PCI Express x1, x2, x4, x8 and x16 lane buses, and configurable COM port settings provide a flexible way to customize its use to various needs.
- Easily adds two configurable serial ports to a desktop computer.
- Fits PCI Express x1, x2, x4, x8 and x16 lane buses.
- Fits standard and low-profile PCI slots.
- Plug and Play installation; hot-swappable — Windows compatible.
- Manhattan Serial PCI Express Card - serial adapter
- Serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- Ports
- RS-232 x 2
- Data Link Protocol
- Serial
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows 2000/XP/Vista/7
- Limited lifetime warranty
- Serial adapter
- Form Factor
- Plug-in card
- PCI Express x1
- Ports
- RS-232 x 2
- Connectivity Technology
- Wired
- Serial
- 2 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI Express
- Plug and Play
- Software Included
- Driver
- OS Required
- Additional Requirements
- CD-ROM
- Limited warranty - lifetime
