The MANHATTAN stereo headphones combine quality performance and comfortable design with a good value. The padded foam ear cushions and split headband adjust to fit almost any listener. A long, durable cable with a single 3.5 mm stereo plug helps maintain a reliable connection to desktop and notebook computers and other audio devices.
- Manhattan Stereo Headphones - headphones
- Product Type
- Headphones - wired - 3.5 mm jack
- Recommended Use
- Computer
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 100 dB
- Impedance
- 32 Ohm
- Limited lifetime warranty
- Product Type
- Headphones - 3.5 mm jack
- 57 g
- Black
- Recommended Use
- Computer
Headphones
- Supraaural
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 100 dB
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
- Connector Type
- Headphones (mini-phone stereo 3.5 mm)
- Cables Included
- Headphones cable - 2.2 m
- Included Accessories
- Headphones earpads
- FCC, RoHS, WEEE
- Limited warranty - lifetime
