The MAGNESE Office power adapter offers durable and portable laptop charging. This is the ideal replacement for laptop chargers, available for a wide range of laptop models and geographical regions.
- Magnese - power adapter - 120 Watt
- Power adapter - external
- Power Capacity
- 120 Watt
- Designed For
- HP Pavilion Laptop dv6, dv7
- Power Capacity
- 120 Watt
- Designed For
- HP Pavilion Laptop dv6-1009tx, dv6-1012tx, dv6-1013ea, dv6-1013tx, dv6-1016ez, dv6-1020ej, dv6-1020eq, dv6-1023em, dv6-1025ef, dv6-1025ei, dv6-1025ez, dv6-1040ej, dv6-1042el, dv6-1044el, dv6-1050ei, dv6-1060ev, dv6-1062el, dv6-1066el, dv6-1068el, dv6-1080eq, dv6-1100so, dv6-1100ss, dv6-1100sv, dv6-1101ax, dv6-1101tu, dv6-1101tx, dv6-1102ax, dv6-1102tx, dv6-1103ee, dv6-1103eo, dv6-1103tx, dv6-1104tx, dv6-1105ee, dv6-1105sl, dv6-1106tx, dv6-1107tx, dv6-1108ca, dv6-1108tx, dv6-1109tx, dv6-1110ec, dv6-1110eg, dv6-1110eq, dv6-1110et, dv6-1110tx, dv6-1115ei, dv6-1115et, dv6-1115ez, dv6-1119el, dv6-1120ec, dv6-1120ei, dv6-1120ej, dv6-1120ek, dv6-1120eq, dv6-1120sk, dv6-1122tx, dv6-1123ee, dv6-1124ca, dv6-1125ee, dv6-1125el, dv6-1125er, dv6-1125et, dv6-1125tx, dv6-1127cl, dv6-1128tx, dv6-1130ec, dv6-1130ei, dv6-1130ek, dv6-1132tx, dv6-1133et, dv6-1134ca, dv6-1135ei, dv6-1140ec, dv6-1140ei, dv6-1140ek, dv6-1140ez, dv6-1145eg, dv6-1149et, dv6-1150ec, dv6-1150ei, dv6-1157ez, dv6-1160ei, dv6-1160ej, dv6-1199ee, dv6-1246eo, dv6-2000st, dv6-2005ev, dv6-2005sl, dv6-2006eg, dv6-2010ec, dv6-2010sa, dv6-2010ss, dv6-2010st, dv6-2010sv, dv6-2012ef, dv6-2014er, dv6-2015er, dv6-2016ez, dv6-2017eg, dv6-2017er, dv6-2019er, dv6-2020er, dv6-2020ev, dv6-2022er, dv6-2025er, dv6-2026es, dv6-2028es, dv6-2028ez, dv6-2030er, dv6-2040er, dv6-2043el, dv6-2051el, dv6-2055er, dv6-2059eo, dv6-2062eo, dv6-2065et, dv6-2070ez, dv6-2090er, dv6-2130et, dv6-2131et, dv6-2132se, dv6-2132sf, dv6-2133ee, dv6-2133se, dv6-2134eo, dv6-2134et, dv6-2135ec, dv6-2135er, dv6-2135et, dv6-2135ev, dv6-2136ev, dv6-2140ee, dv6-2140ei, dv6-2140ep, dv6-2140es, dv6-2143ez, dv6-2145eo, dv6-2145et, dv6-2147eo, dv6-2150ek, dv6-2150eq, dv6-2150et, dv6-2152ee, dv6-2153ee, dv6-2153eo, dv6-2156et, dv6-2157et, dv6-2157ez, dv6-2165eo, dv6-2165et, dv6-2167ss, dv6-2170ef, dv6-2170et, dv6-2180ek, dv6-2185es, dv6-2190ev, dv6-2195et, dv6-3306el, dv6-6011el, dv6-6129sl, dv6-6151el, dv6-6196ep
