Your basket is empty
Maclocks Tablet 10"-12" Secured Cling-On Bracket With Wall Mount Unit
Quicklinx: B87FWS00 Mfr#: 174SCLG10-12S
The iPad Air Lock is a sturdy one piece solution made of high grade steel. Securing your tablet are tamper-proof screws that tighten the bracket around the narrow side of the device, locking it to the stand base.
The Cling-On Stand has 90 degree screen rotation that allows your tablet to be displayed in either landscape or portrait orientation mode, with the ability to fix the angle as desired. This feature makes it perfect for use as an iPad POS stand, retail kiosk, public display and desk companion.
The Cling-On Stand offers two added levels of security in that it can be bolted to a flat surface, like a counter or even wall mounted, or used as a free moving kiosk when paired with one of security cable locks.
Compulocks Universal Secure Cling on and stand / Kiosk for tablets - For Full size tablets - stand
Stand - wall-mountable, table-top, surface mountable
20.5 cm
Recommended Use
Tablet
Recommended Display Size
9"-11"
Material
Steel
20.5 cm
Material
Steel
AV Furniture
Stand
Recommended Use
Tablet
Placing / Mounting
Wall-mountable, table-top, surface mountable
9"-11"
Tamper resistant adjustment screws, portrait to landscape movement, bolt-down security
Dimensions & Weight Details
Dimensions
Base - width: 15 cm, depth: 10 cm
Inner Size
Tablet compartment - width: 19 cm, depth: 0.99 cm
