Your basket is empty
Maclocks Surface Pro 3 Space Enclosure With Pole Mount Kiosk - Black
Quicklinx: B8DTWS00 Mfr#: 920B530GEB
The Rokku design includes a high security cylinder lock mechanism and a recessed frame for a full tamper proof enclosure. Access to the on/off and volume buttons are blocked while still allowing for charging and limited audio port access.
Constructed of high grade aluminum makes the Rokku Surface enclosure extremely lightweight and durable at the same time. With soft edges and rounded corners the aesthetic of this enclosure is very appealing and fits all display environments.
Although very thin at only 3 cm (1.18 in) deep, the sunken frame design allows for full cable management adding another level security to your Surface. The Rokku Surface enclosure includes a standard 100 mm x 100 mm VESA pattern which will allow it to be mounted to flat surfaces and a collection of mounts.
Compulocks Surface Secure Space Enclosure with Pole Stand Kiosk Black - stand
Stand - table-top
Recommended Use
Tablet
Material
High-grade aluminium
Microsoft Surface Pro 3
Material
AV Furniture
Stand
Recommended Use
Tablet
Placing / Mounting
Table-top
Cable Management
Integrated cable management
