The Swan Surface Tablet Kiosk is the newest release from Compulocks. Elegantly designed with a white "swan-neck" sloping stand your Surface Tablet Kiosk bring a level of class to any setting.
The surface tablet stand is angled at 60 degrees for optimal viewing and sits 14 inches (35 cm) high and at the base is 7 inches (18 cm) wide. The enclosure rotates 90 degrees for smooth transition between landscape and portrait mode.
The wiring will come out the rear of the stand for a clean look and the base can be bolted to a counter top for security. It has a keyed lock for easy access to the your Surface Tablet when you need to take it with you or maintenance is required.
- Compulocks Surface Secure Space Enclosure with Swan Stand Kiosk Black enclosure - for tablet - black
- Product Type
- Enclosure - desktop
- Recommended Use
- Tablet
- Recommended Display Size
- 12"
- Material
- Aluminium
- Black
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Designed For
- Microsoft Surface Pro 3
- Material
- Aluminium
- Black
AV Furniture
- Enclosure
- Recommended Use
- Tablet
- Placing / Mounting
- Desktop
- Cable Management
- Integrated cable management
- 12"
- Portrait to landscape movement, lockable
Dimensions & Weight Details
- Dimensions
- Enclosure - width: 30 cm, depth: 2 cm, height: 23 cm
- Designed For
