Product
Brand
Maclocks Space 10.6" Surface Enclosure With Pole Mount Kiosk - Black
Quicklinx: B8DHWS00 Mfr#: 920B500GEB
The Maclocks Pole Surface Kiosk is the next in the line of surface tablet security display products that offers full cable management. Ideal for use as a display kiosk or information stand specifically in high volume areas. You can be confident that your device will stay continually connected and secure.
Fully constructed of high-grade aluminum for maximum security that won't bend or break creating a tamper proof solution for your Surface Tablet deployment.
The Pole Surface Stand displays your Surface at a 60 degree angle for comfortable viewing and encourages engagement. With smooth rotation between landscape and portrait modes you can easily display a wide range of content and utilize any app.
Compulocks Surface Secure Space Enclosure with Pole Stand Kiosk Black - stand
Stand - table-top - lockable
Recommended Use
Tablet
Material
High-grade aluminium
Microsoft Surface 2, Pro, Pro 2
Material
AV Furniture
Stand
Recommended Use
Tablet
Placing / Mounting
Table-top
Cable Management
Integrated cable management
Lockable
