Product
Maclocks Space 10.6" Surface Enclosure Swing Arm Wall Mount - Black
Quicklinx: B8DDWS00 Mfr#: 827B500GEB
The Surface Tablet Space Enclosure Swing secure mount is the ideal Surface Tablet security solution for all display settings including education, health-care, corporate, retail and point of sale environments.
The Space Enclosure for Surface Tablet Kiosk has open corners for proper ventilation and access to the audio and charging ports for continuous charging. These features allow for a fully functional device even when locked in the Surface Tablet Enclosure. The keyed lock makes it easy to access when tablet maintenance is required.
The Surface Tablet Space Enclosure Swing mount is the perfect solution for corners, bar table tops, under cabinets, or simply where some extra versatility or space is needed. The tension screws allow for precise fluid or locked movement and the 90 degree rotation makes it the perfect choice for both landscape and portrait orientation modes.
Compulocks Surface Secure Space Enclosure with Swing Arm Kiosk Black - mounting kit
Mounting kit - wall-mountable
Mounting Components
Swing arm, anti-theft enclosure
Recommended Use
Tablet
Recommended Display Size
10"
Material
Aluminium
Microsoft Surface 2, Pro, Pro 2
Material
Aluminium
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Tablet
Placing / Mounting
Wall-mountable
10"
Portrait to landscape movement, cable lock
Dimensions & Weight Details
Dimensions
Frame - width: 2 cm, depth: 30 cm, height: 23 cm
