Maclocks MacBook Air 11 Case Lock
Quicklinx: B84CWS00 Mfr#: MBA11BUN
Most MacBook Air owners use a cover/skin to protect their computer. Maclocks created a simple but clever solution: it incorporates a neat cover that also protects your MacBook Air via an integrated built-in security slot that can accommodate any of the standard cable locks sold on the market.
Once the case and cable are locked together, thieves can't detach the case without damaging the MacBook Air. This makes the MacBook Air Lock flexible and light, not to mention stylish, so you can easily pack it in your bag and take it with you wherever you go.
Compulocks MacBook Lockable Case Bundle With T-Bar Cable Lock and MacBook Air 11" Security Case / Cover Clear - security cable lock
Security cable lock
Package Content
2 x keys, security case, security cover
Clear
Product Material
Galvanised steel
Length
1.83 m
1-year warranty
Security cable lock
Product Material
Galvanised steel
Package Content
Length
1.83 m
Clear
Limited warranty: - 1 year
