Maclocks Mac Mini Lock
Price Drop!
Clearance
Last Few Remaining
Price Drop
Quicklinx: B84ZWS00 Mfr#: MMEN76
£38.05 ex VAT
£45.66 inc VAT
Well it doesn't get much easier, you can mount the Mac mini using a security bracket to any surface utilizing the standard set of 75 or 100 VESA mount holes. This Mac mini mount is made from 100% solid high grade aluminum construction and makes for a great security solution. You slide the Mac mini into the Mac mini mount and security bracket, secure the lock in place and you are good to go - all in seconds. The loop-ended security cable is galvanized steel and the cable can be looped around a stationary object.
Compulocks Mac Mini Lock Security Enclosure - Lock Head Included system security kit
System security kit
Placing / Mounting
Wall mountable, under-desk mountable
Package Content
Lock
Product Material
Aluminium
Top mountable, rear mountable, VESA interface support
Apple Mac mini (Late 2012, Late 2014, Mid 2010, Mid 2011)
System security kit
Placing / Mounting
Product Material
Aluminium
Package Content
Lock
Maclocks Mac Mini Lock Bundle deal on Maclocks Mac Mini Lock
£137.22
Brand: Maclocks
Price Range Ex VAT: 0 - 50
