Maclocks iPad Space Enclosure with Reach Articulating Arm - Black
Quicklinx: B890WS00 Mfr#: 660REACH224SENB
£227.27 ex VAT
£272.72 inc VAT
Allow your work space to "Reach new heights" with the Space Reach iPad Articulating desk mount. Tilt, swivel, extend and retract your iPad with a smooth gliding motion that can be easily adjusted to your liking.
Click the Space iPad Enclosure into the cradle and free your hands to use a wireless keyboard or other Bluetooth devices. Adjust the screen so you can work comfortably or share information while your iPad floats above your desk alongside other screens and devices.
Setting up the Reach Arm is quick and easy with a no-screw tightening clamp. First fasten the base to the surface edge, then connect the arms to the base. Before you put your iPad into the enclosure, screw on the VESA Click plate to the back plate of the Space. Once the Space iPad enclosure and Reach arm are set up, you can lock in your iPad. Wire the included security lock through the cable management system and loop the end to a table leg or anchoring point.
The Reach is the perfect desk companion for any business or home environment including: Retail, Laboratory, Garage, Classroom, Kitchen, Hospital, Clinics, and many more!
Compulocks Space Reach - iPad 9.7" Counter Top Articulating Arm - Black - mounting kit
Mounting kit - desktop
Mounting Components
Articulating arm, executive enclosure
Adjustments
Tilt
Recommended Use
Apple iPad
VESA Mounting Interface
100 x 100 mm
Apple iPad (3rd generation); iPad 2; iPad Air; iPad Air 2; iPad with Retina display (4th generation)
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Apple iPad
Placing / Mounting
Desktop
100 x 100 mm
Cable Management
Integrated cable management
Adjustments
Tilt
Swivel adjustment, cable lock
Apple iPad (3rd generation) , Apple iPad 2 , Apple iPad Air , Apple iPad Air 2 , Apple iPad with Retina display (4th generation)
Maclocks iPad Space Enclosure with Reach Articulating Arm - Black Bundle deal on Maclocks iPad Space Enclosure with Reach Articulating Arm - Black
£327.03
Brand: Maclocks
Price Range Ex VAT: 150 - 300
