The Swan iPad Enclosure Kiosk is the newest release from Maclocks. Elegantly designed with a white "swan-neck" sloping stand your new iPad Kiosk will bring a level of class to any setting.
The iPad stand is angled at 60 degrees for optimal viewing and sits 14 inches (35cm) high and at the base is 7 inches (18cm) wide. The iPad enclosure rotates 90 degrees for smooth transition between landscape and portrait mode.
The wiring will come out the rear of the stand for a clean look and the base can be bolted to a counter top for security. It has a keyed lock for easy access to your iPad when you need to take it with you or maintenance is required.
- Compulocks iPad Secure Space Enclosure with Swan Stand Kiosk White stand - for tablet - white
- Product Type
- Stand - desktop
- Recommended Use
- Tablet
- White
- White
AV Furniture
- Stand
- Recommended Use
- Tablet
- Placing / Mounting
- Desktop
- Portrait to landscape movement, lockable
Dimensions & Weight Details
- Dimensions
- Base - width: 18 cm
