This tablet kiosk is ideal for use as a display kiosk or information stand specifically in high-volume areas. You can be confident that your device will stay continually connected and secure. Fully constructed of high-grade aluminum for maximum security it won't bend or break creating a tamper-proof solution for your tablet deployment. The stand displays your tablet at a wide angle for comfortable viewing and encourages engagement. With smooth rotation between landscape and portrait modes you can easily display a wide range of content and utilize any app. With a minimal amount of setup required you can have your tablet enclosure kiosk ready to go in just a few minutes. It is a great solution for any business or public display environments.
- Compulocks stand - for tablet - white
- Product Type
- Stand - desktop
- Recommended Use
- Tablet
- Material
- Aluminium
- White
- Material
- Aluminium
- White
AV Furniture
- Stand
- Recommended Use
- Tablet
- Placing / Mounting
- Desktop
- Cable Management
- Integrated cable management
- Portrait to landscape movement
