The SLIDE Stand iPad POS Stand is a complete display option to use your iPad POS in a professional setting. This POS Stand is a great option for use in front of the house or greeting function and will save you valuable counter or table top space.
The SLIDE Stand has a 45 degree screen angle for ideal viewing and safe interaction. The wires are housed in the base so you always have a clean look and the 90 degree rotation makes it the perfect choice for both landscape and portrait orientation needs. The iPad POS Stand has a stable, all steel base to prevent tip-overs at any screen angle.
- Compulocks iPad Secure Slide POS with Adjustable Floor Stand Kiosk White enclosure - Anti-Theft - for tablet - white
- Product Type
- Enclosure (Anti-Theft)
- 27.9 cm x 33 cm x 112 cm
- Adjustments
- Tilt
- Recommended Use
- Tablet
- Material
- Steel
- White
- 27.9 cm
- 33 cm
- 112 cm
- Material
- Steel
- White
AV Furniture
- Enclosure
- Design
- Anti-Theft
- Recommended Use
- Tablet
- Adjustments
- Tilt
- Adjustable height, portrait to landscape movement, lockable, ventilation system
Dimensions & Weight Details
- Dimensions
- Enclosure - width: 24.5 cm, depth: 3 cm, height: 24.5 cm , Base - width: 27.9 cm, depth: 33 cm, height: 112 cm
