Your basket is empty
Maclocks iPad Air POS Floor Stand Kiosk - Black
Quicklinx: B86XWS00 Mfr#: 147B257POSB
The SLIDE Stand iPad POS Stand is a complete display option to use your iPad POS in a professional setting. This POS Stand is a great option for use in front of the house or greeting function and will save you valuable counter or table top space.
The SLIDE Stand has a 45 degree screen angle for ideal viewing and safe interaction. The wires are housed in the base so you always have a clean look and the 90 degree rotation makes it the perfect choice for both landscape and portrait orientation needs. The iPad POS Stand has a stable, all steel base to prevent tip-overs at any screen angle.
Compulocks iPad Secure Slide POS with Adjustable Floor Stand Kiosk Black - stand
Stand - floor-standing
Tilt
Recommended Use
Tablet
Material
Steel
Apple iPad Air; iPad Air 2
Material
Steel
AV Furniture
Stand
Recommended Use
Tablet
Placing / Mounting
Floor-standing
Cable Management
Integrated cable management
Tilt
Portrait to landscape movement, ventilation system
Dimensions & Weight Details
Dimensions
Enclosure - width: 24.5 cm, depth: 3 cm, height: 24.5 cm , Base - width: 27.9 cm, depth: 33 cm, height: 112 cm
Apple iPad Air , Apple iPad Air 2
