The SLIDE Stand iPad POS Stand is a complete display option to use your iPad POS in a professional setting. This POS Stand is a great option for use in front of the house or greeting function and will save you valuable counter or table top space.
The customizable display panel allows you to draw attention to the Stand and will give your establishment a commercial feel.
- Compulocks iPad Secure Slide POS with BrandMe Floor Stand Kiosk White stand - for tablet - white
- Product Type
- Stand - floor-standing
- Adjustments
- Tilt
- Recommended Use
- Tablet
- Material
- Steel
- White
- Material
- Steel
- White
AV Furniture
- Stand
- Recommended Use
- Tablet
- Placing / Mounting
- Floor-standing
- Cable Management
- Integrated cable management
- Adjustments
- Tilt
- Portrait to landscape movement, ventilation system
Dimensions & Weight Details
- Dimensions
- Enclosure - width: 24.5 cm, depth: 3 cm, height: 24.5 cm , Base - width: 27.9 cm, depth: 33 cm, height: 112 cm
