The Galaxy Tab Space Enclosure Swing secure mount is the ideal Galaxy Tab security solution for all display settings including education, health-care, corporate, retail and point of sale environments.
The Space Enclosure for Galaxy Tab Kiosk has open corners for proper ventilation and access to the audio and charging ports for continuous charging. These features allow for a fully functional device even when locked in the Galaxy Tab Enclosure. The keyed lock makes it easy to access when tablet maintenance is required.
The Galaxy Tab Space Enclosure Swing mount is the perfect solution for corners, bar table tops, under cabinets, or simply where some extra versatility or space is needed. The tension screws allow for precise fluid or locked movement and the 90 degree rotation makes it the perfect choice for both landscape and portrait orientation modes.
- Compulocks Galaxy Secure Space Enclosure with Swing Arm Kiosk White enclosure - for tablet - white
- Product Type
- Enclosure - wall-mountable
- Recommended Use
- Tablet
- Material
- Aluminium
- White
- Designed For
- Samsung Galaxy Tab 3 (8 in), Tab 4 (8 in)
- Material
- Aluminium
- White
AV Furniture
- Enclosure
- Recommended Use
- Tablet
- Placing / Mounting
- Wall-mountable
- Portrait to landscape movement, padded, security lock slot (cable lock sold separately)
Dimensions & Weight Details
- Dimensions
- Enclosure - width: 30 cm, depth: 2 cm, height: 23 cm
- Designed For
