Your basket is empty
Maclocks Galaxy 8" Space Enclosure With Pole Mount Kiosk - White
Quicklinx: B8D2WS00 Mfr#: 920W480GEW
The Maclocks Pole Galaxy Tab is the next in the line of Galaxy Tab security display products that offers full cable management. Ideal for use as a display kiosk or information stand specifically in high volume areas. You can be confident that your device will stay continually connected and secure.
Fully constructed of high-grade aluminum for maximum security that won't bend or break creating a tamper proof solution for your Galaxy Tab deployment.
The Pole Galaxy Tab Stand displays your Galaxy at a 60 degree angle for comfortable viewing and encourages engagement. With smooth rotation between landscape and portrait modes you can easily display a wide range of content and utilize any app. With a minimal amount of setup required you can have your Galaxy Tab enclosure kiosk ready to go in just a few minutes.
Compulocks Galaxy Secure Space Enclosure with Pole Stand Kiosk White - stand
Stand - table-top
Recommended Use
Tablet
Material
Aluminium
White
Samsung Galaxy Tab 3 (8 in), Tab 4 (8 in)
Material
Aluminium
White
AV Furniture
Stand
Recommended Use
Tablet
Placing / Mounting
Table-top
Cable Management
Integrated cable management
Portrait to landscape movement, lockable, tamper resistant
