Your basket is empty
Maclocks Galaxy 7" Space Enclosure With Flex Arm Mount - White
Quicklinx: B8BVWS00 Mfr#: 159W470GEW
The Galaxy Tab A Space Enclosure secure wall mount is the ideal Galaxy Tab A security solution for all display settings including education, health-care, corporate, retail and point of sale environments.
The Space Enclosure for Galaxy Tab A Kiosk has open corners for proper ventilation and access to the audio and charging ports for continuous charging. These features allow for a fully functional device even when locked in the Galaxy Tab Enclosure. The keyed lock makes it easy to access when tablet maintenance is required.
The flex arm at full reach comes out to 12" off the secured surface and is great for mounting on the wall, under a cabinet, underside of a table and more.
Compulocks Space Flex Arm - Galaxy Tab A 9.7" Counter Top Kiosk - White - enclosure
Enclosure - wall-mountable
Recommended Use
Tablet
Material
Aluminium
White
Samsung Galaxy Tab 3 (7 in), Tab 4 (7 in)
Material
Aluminium
White
AV Furniture
Enclosure
Recommended Use
Tablet
Placing / Mounting
Wall-mountable
Lockable, padded, security lock slot (cable lock sold separately), flexible arm
Dimensions & Weight Details
Dimensions
Enclosure - width: 30 cm, depth: 2 cm, height: 20 cm
