The Galaxy Swan Kiosk for Galaxy Tab 7/8/10.1 and Galaxy Note 10.1 is the newest release from GalaxyEnclosures. Elegantly designed with a white "swan-neck" sloping stand your Galaxy Kiosk bring a level of class to any setting.
The Galaxy stand is angled at 60 degrees for optimal viewing and sits 14 inches (35 cm) high and at the base is 7 inches (18 cm) wide. The enclosure rotates 90 degrees for smooth transition between landscape and portrait mode.
The wiring will come out the rear of the stand for a clean look and the base can be bolted to a counter top for security. It has a keyed lock for easy access to the your Galaxy tablet when you need to take it with you or maintenance is required.
- Compulocks Galaxy Secure Space Enclosure with Swan Stand Kiosk White stand - for tablet - white
- Product Type
- Stand - desktop
- Recommended Use
- Tablet
- White
- Designed For
- Samsung Galaxy Tab 3 (7 in), Tab 4 (7 in)
- White
AV Furniture
- Stand
- Recommended Use
- Tablet
- Placing / Mounting
- Desktop
- Portrait to landscape movement, lockable
Dimensions & Weight Details
- Dimensions
- Base - width: 18 cm
- Designed For
