Product
Maclocks Galaxy 360 Tab 3 Kiosk - Black
Quicklinx: B869WS00 Mfr#: 303B300GEB
The Galaxy Tab 3 Enclosure secure Kiosk is the ideal Galaxy security solution for all display settings including education, health-care, corporate, retail and point of sale environments.
The 360 All In One Kiosk has a full tilt for an easy was to reverse the screen for ideal viewing and safe interaction. A wiring pass-through cutout keeps the look clean and the 90 degree rotation makes it the perfect choice for both landscape and portrait orientation needs.
The Galaxy Tab 3 360 All In One Enclosure Kiosk is closed on all sides to provide a tamper-proof security solution but has a cutout inset for access to all the buttons on the front bezel. The charging cable is secured within the enclosure with an opening for the wire to allow for mounted charging. The Kiosk can be fastened to a table top or flat service through the holes in the base of the stand.
The Galaxy Tab 3 Enclosure Kiosk has a stable, all steel base to prevent tip-overs at any screen angle.
Compulocks Full Jacket 360 - Galaxy Tab 3 10.1" Counter Top Kiosk - Black - stand (Tilt & Swivel)
Stand (Tilt & Swivel) - desktop
30 cm x 2 cm x 20 cm
Pan
360°
Adjustments
Tilt
544 g
Recommended Use
Tablet
Material
Aluminium, steel
Samsung Galaxy Tab 3 (10.1 in)
30 cm
2 cm
20 cm
544 g
Material
Aluminium, steel
AV Furniture
Stand
Design
Tilt & Swivel
Recommended Use
Tablet
Placing / Mounting
Desktop
Pan
360°
Adjustments
Tilt
Portrait to landscape movement, lockable, swivel adjustment, tamper-resistant
Dimensions & Weight Details
Dimensions
Base - width: 13.8 cm, depth: 12 cm, height: 18 cm
