The Maclocks Pole Galaxy Tab is the next in the line of Galaxy Tab security display products that offers full cable management. Ideal for use as a display kiosk or information stand specifically in high volume areas. You can be confident that your device will stay continually connected and secure.
Fully constructed of high-grade aluminum for maximum security that won't bend or break creating a tamper proof solution for your Galaxy Tab deployment.
The Pole Galaxy Tab Stand displays your Galaxy at a 60 degree angle for comfortable viewing and encourages engagement. With smooth rotation between landscape and portrait modes you can easily display a wide range of content and utilize any app. With a minimal amount of setup required you can have your Galaxy Tab enclosure kiosk ready to go in just a few minutes.
- Compulocks Galaxy Secure Space Enclosure with Pole Stand Kiosk White stand - for tablet - white
- Product Type
- Stand - desktop
- Recommended Use
- Tablet
- Recommended Display Size
- 10"
- Material
- Aluminium
- White
- Designed For
- Samsung Galaxy Note 10.1, Note 10.1 LTE, Note 10.1 WiFi, Tab 10.1, Tab 10.1 WiFi, Tab 2 (10.1), Tab 2 (10.1) WiFi, Tab 3 (10.1 in), Tab 4 (10.1 in)
- Material
- Aluminium
- White
AV Furniture
- Stand
- Recommended Use
- Tablet
- Placing / Mounting
- Desktop
- Cable Management
- Integrated cable management
- 10"
- Portrait to landscape movement, lockable, tamper-resistant
- Designed For
