Product
Maclocks Galaxy 10.1" Space Enclosure With Flex Arm Mount - White
Quicklinx: B8BFWS00 Mfr#: 159W400GEW
Stock Status: Clearance, Used Stock
Sorry but this product has been discontinued.
View used stock
The Galaxy Tab A Space Enclosure secure wall mount is the ideal Galaxy Tab A security solution for all display settings including education, health-care, corporate, retail and point of sale environments.
The Space Enclosure for Galaxy Tab A Kiosk has open corners for proper ventilation and access to the audio and charging ports for continuous charging. These features allow for a fully functional device even when locked in the Galaxy Tab Enclosure. The keyed lock makes it easy to access when tablet maintenance is required.
The flex arm at full reach comes out to 12" off the secured surface and is great for mounting on the wall, under a cabinet, underside of a table and more.
Compulocks Space Flex Arm - Galaxy Tab A 9.7" Counter Top Kiosk - White - enclosure
Enclosure - wall-mountable
Recommended Use
Tablet
Material
Aluminium
White
Samsung Galaxy Note 10.1, Note 10.1 LTE, Note 10.1 WiFi, Tab 10.1, Tab 10.1 WiFi, Tab 2 (10.1), Tab 2 (10.1) WiFi, Tab 3 (10.1 in), Tab 4 (10.1 in)
Material
Aluminium
White
AV Furniture
Enclosure
Recommended Use
Tablet
Placing / Mounting
Wall-mountable
Lockable, padded, security lock slot (cable lock sold separately), flexible arm
Dimensions & Weight Details
Dimensions
Enclosure - width: 30 cm, depth: 2 cm, height: 20 cm
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: B8BF 037345
Condition: Customer return - item has been used but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £17.29
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Maclocks
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
