The Galaxy Tab Space Enclosure Swing secure mount is the ideal Galaxy Tab security solution for all display settings including education, health-care, corporate, retail and point of sale environments.
The Space Enclosure for Galaxy Tab Kiosk has open corners for proper ventilation and access to the audio and charging ports for continuous charging. These features allow for a fully functional device even when locked in the Galaxy Tab Enclosure. The keyed lock makes it easy to access when tablet maintenance is required.
The Galaxy Tab Space Enclosure Swing mount is the perfect solution for corners, bar table tops, under cabinets, or simply where some extra versatility or space is needed. The tension screws allow for precise fluid or locked movement and the 90 degree rotation makes it the perfect choice for both landscape and portrait orientation modes.
- Compulocks Galaxy Secure Space Enclosure with Swing Arm Kiosk Black mounting kit - for tablet - black
- Product Type
- Mounting kit
- Mounting Components
- Wall arm, swing arm
- 2 cm x 30 cm x 23 cm
- Adjustments
- Tilt
- 540 g
- Recommended Use
- Tablet
- Recommended Display Size
- 10.1"
- Material
- Aluminium
- Black
- Designed For
- Samsung Galaxy Note 10.1, Note 10.1 LTE, Note 10.1 WiFi, Tab 10.1, Tab 10.1 WiFi, Tab 2 (10.1), Tab 2 (10.1) WiFi, Tab 3 (10.1 in), Tab 4 (10.1 in)
- 2 cm
- 30 cm
- 23 cm
- 540 g
- Material
- Aluminium
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Tablet
- 10.1"
- Adjustments
- Tilt
- Rotating, portrait to landscape movement, lockable
- Designed For
