Lumens Gooseneck Full HD 1080p Resolution Document Camera
Quicklinx: B79WWS00 Mfr#: DC170
Equipped with a professional image sensor with low noise and vivid color reproduction, it supports extremely tremely high definition Full HD 1080p, SXGA, and vanes signal formats for crystal-clear image. Highly flexible and joint-free gooseneck design ensures smooth quality without vibration, easy to use, and 3600 viewing angle.
  • Excellent image quality
    Equipped with a professional image sensor with low noise and vivid color reproduction. It supports extremely tremely high definition Full HD 1080p, SXGA, and vanes signal formats for crystal-clear image.
  • Video/audio recording and extra storage
    With a built-in microphone and just one-button to record video and audio synchronously on board directly without a PC. The SD card storage is convenient to record training, meetings, seminars, lectures.
  • Built-in power
    With a much more stable power supply and less things to detach you can be sure of a constant image and data flow.
  • HDMI interface
    Utilize a standard HDMI interface for the high quality digital video transmission, and simplify system integration.
  • Anti-reflection
    With the Lumens side lamp gooseneck design, the direction of the light source can be adjusted according to the environment to prevent reflections
  • Auto tune
    With the convenient single button to adjust the clarity, brightness, and color according to the actual environment automatically.
  • Extremely smooth dynamic image
    With 30 fps capture every tiny movement during playback without delays. Even flapping insect wings can be clearly observed in great detail.
  • Joint-free gooseneck
Lumens DC 170 - digital document camera
Digital document camera
Audio
Yes: built-in microphone
42 cm x 14 cm x 39.5 cm
1.9 kg
Wired
Camera
Optical Zoom
8.5 x
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Focus Adjustment
Automatic (min distance 4 cm)
USB 2.0, VGA, HDMI
Digital image rotation, SD-card slot, image flip, image mirror, built-in LED lights, security lock slot (cable lock sold separately)
Audio Support
Wired
42 cm
14 cm
39.5 cm
1.9 kg
Camera
Max Digital Video Resolution
1920 x 1080
Digital Zoom
10
Frame Rate (max)
Still Image Capture Resolution
1280 x 960, 1024 x 768, 1280 x 768, 1920 x 1080
Lens Construction
Optical Zoom
8.5 x
Focus Adjustment
Automatic
Min Focus Distance
4 cm
Video
VGA, HDMI
Computer Interface
USB 2.0
Interfaces Details
1 x USB 2.0 - 4 pin USB Type B , 1 x display / video - VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio / video - HDMI output - RCA , 1 - RS-232/composite video output , 1 x display / video - VGA input - 15 pin HD D-Sub (HD-15) , 1 x audio - output
Power supply - internal AC 120/230 V
Apple MacOS X, Microsoft Windows Vista / XP / 7
