Your basket is empty
Lumens 5000 Lumens WXGA 3LCD Installation Projector
Quicklinx: C0K2WS00 Mfr#: V11H748041
Portability: Non-portable
Hurry, only 2 left in stock!
£1,076.09 ex VAT
£1,291.30 inc VAT
High-quality content
Showcase your important presentations in the best possible way with the EB-4770W. Thanks to Epson's 3LCD technology, you can be sure that your projected images will feature accurate colours and clear detail. Your images will continue to look their best even in brightly-lit rooms thanks to high brightness and an equally high White and Colour Light Output.
Flexible connectivity
Bring your presentations to life with a range of high-definition content, which can be projected from a variety of devices connected via the HDMI and DisplayPort inputs. Content from these devices can also be displayed alongside content from another source, such as a separate laptop or Epson USB Visualiser, using the side-by-side split screen function.
Easy set-up and maintenance
Setting up the projector is quick and easy thanks to a variety of user-friendly installation features, meaning you can get started quickly. You can place the projector in a number of positions without fear of blurring or distorting the image thanks to its x1.8 wide zoom ratio, keystone correction and arc and point correction. We have also made it easy for you to keep your projections as bright and clear as possible. Both the lamp and filter are easy to replace, meaning maintenance is quick and straightforward.
Epson EB-4770W LCD projector
LCD projector - High Definition 720p
Built-in Devices
Speaker
Brightness (White)
5000 lumens
Brightness (Colour)
5000 lumens
Contrast Ratio
5000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens Shift Direction
Horizontal, vertical
Bulb type
UHE 280 Watt
Bulb life cycle
Up to 4000 hours / up to 5000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video LAN
Speakers
Speaker(s) - integrated
AC 120/230 V ( 50/60 Hz )
388 Watt
47.2 cm x 35.4 cm x 15.9 cm
6.6 kg
3 years warranty
LCD projector - HD 720p
Built-in Devices
Speaker
Ethernet
Projector
Brightness (White)
5000 lumens
Brightness (Colour)
5000 lumens
Brightness (Reduced)
3000 lumens
Contrast Ratio
5000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
1.4 m - 15 m
Throw Ratio
1.26 - 2.3:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
UHE 280 Watt
Bulb life cycle
sRGB colour profile, EPSON Quick Corner, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.65-2.55
Zoom Factor
1.8x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Vertical Lens Shift
50% / 50%
Horizontal Lens Shift
10% / 10%
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, component video, composite video, S-Video
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Output Power / Channel
10 Watt
1 x component video input - BNC x 5 , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - mini-DIN , 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort input , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) ( management )
Cable cover, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), lens lock
Nominal Voltage
388 Watt
Power Consumption Stand by
0.39 Watt
Software Included
Drivers & Utilities, EasyMP Network Projection, EasyMP Monitor
47.2 cm
35.4 cm
15.9 cm
6.6 kg
Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
20 - 80%
Sound Emission
38 dB
32 dB
C0K2 C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE In Stock £7.76
C0K2 C2G HDMI to DisplayPort Adapter Converter In Stock £38.91
C0K2 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £24.16
C0K2 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £10.10
C0K2 C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £19.71
C0K2 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £17.51
C0K2 C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £14.04
Brand: Lumens
Price Range Ex VAT: 1000 - 1500
