This THX-Certified 2.1 system delivers powerful sound with 200 watts (RMS) of power - for big, bold audio.
THX Certified
These speakers have met strict performance standards to achieve THX certification - for quality you can count on -
With 200 watts (RMS) of power, you can listen as loud as you want to. You'll hear - and feel - immersive audio that brings music, movies and games to life -
Flexible connectivity
RCA and 3.5 mm inputs, as well as a built-in headphone jack, make it easy to get great sound from up to three audio devices -
Powerful 2.1 system
Your powerful 2.1 system delivers easy, two-satellite setup and a powerful subwoofer for big sound - even in large spaces -
Integrated controls
You're in command with integrated controls - dial the volume and bass up or down to customise your listening experience
- Logitech Z-623 - speaker system - for PC
- Product Type
- Speaker system - for PC - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Audio System Peak Power (Total)
- 200 Watt
- Amplifier
- Integrated
- Speaker System Details
- 2 , 1 x subwoofer
- Built-in Decoders
- THX
- 2-year warranty
- Product Type
Speaker System
- System Components
- Speaker Type
- Active
- 200 Watt
- Amplifier
- Integrated
- Built-in Decoders
- THX
- Controls
- Power on/off, volume, bass
- Speakers Included
- 2 - wired , 1 x subwoofer - wired
- Connector Type
- 2 x audio line-in (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2) , Headphones (mini-phone stereo 3.5 mm)
- Power Source
- AC power adapter
- Dimensions (WxDxH) / Weight Details
- Subwoofer: 30.5 cm x 26.6 cm x 28.4 cm / 7 kg , Satellite speaker: 11.7 cm x 12.6 cm x 19.6 cm / 1 kg , Satellite speaker: 11.7 cm x 12.6 cm x 19.6 cm / 950 g
- Limited warranty - 2 years
