Logitech Z50 Multimedia Speaker - Dolphin Grey
Quicklinx: BGXSWS00 Mfr#: 980-000807
Large for a small speaker, the 2.25-inch driver produces 10 W of peak power for a surprisingly loud sound. The mini speaker is compact and portable, giving you the freedom to play your favorite multimedia around the home. It uses an AC power supply, so there is no need to ever recharge your Z50. Designed for Plug and Play simplicity, just connect the Logitech Z50 to your smartphone, tablet or laptop.
  • Small footprint
  • Use with multiple devices
    The 3.5mm audio line in enables you to connect and listen to your favorite multimedia through multiple devices
  • No need to recharge
    The mini speaker uses an AC power supply, so there is no need to ever recharge your Z50
  • Plug and play
    Designed for plug and play simplicity, just connect the Logitech Z50 to your smartphone, tablet or laptop
  • Pick your colour
    The Z50 comes in three eye-catching colours, Pink, Grey, and Blue
Logitech Z50 - speaker
Speaker
Speaker Type
Active
Nominal Output Power
5 Watt
Max Output Power
10 Watt
Frequency Response
100 - 18000 Hz
Nominal Impedance
10 kOhm
Amplifier
Integrated
Speaker System Details
1 x speaker 5 Watt - 100 - 18000 Hz
Grey
9.86 cm x 9.86 cm x 10.65 cm
260 g
2 years warranty
Speaker
Enclosure Colour
Grey
Speaker System
Speaker Type
Active
5 Watt
Max Output Power
10 Watt
Frequency Response
100 - 18000 Hz
Nominal Impedance
10 kOhm
Output Level (1m)
83 dB
Amplifier
Integrated
Speakers Included
1 x speaker - 5 Watt - 100 - 18000 Hz - wired
Driver Details
Speaker: full-range driver - 2.24"
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
AC power adaptor
Power Source
AC power adapter
9.86 cm
9.86 cm
10.65 cm
260 g
