Large for a small speaker, the 2.25-inch driver produces 10 W of peak power for a surprisingly loud sound. The mini speaker is compact and portable, giving you the freedom to play your favorite multimedia around the home. It uses an AC power supply, so there is no need to ever recharge your Z50. Designed for Plug and Play simplicity, just connect the Logitech Z50 to your smartphone, tablet or laptop.
Small footprint
The mini speaker is compact and portable, giving you the freedom to play your favorite multimedia around the home -
Use with multiple devices
The 3.5mm audio line in enables you to connect and listen to your favorite multimedia through multiple devices -
No need to recharge
The mini speaker uses an AC power supply, so there is no need to ever recharge your Z50 -
Plug and play
Designed for plug and play simplicity, just connect the Logitech Z50 to your smartphone, tablet or laptop -
Pick your colour
The Z50 comes in three eye-catching colours, Pink, Grey, and Blue
- Logitech Z50 - speaker
- Product Type
- Speaker
- Speaker Type
- Active
- Nominal Output Power
- 5 Watt
- Max Output Power
- 10 Watt
- Frequency Response
- 100 - 18000 Hz
- Nominal Impedance
- 10 kOhm
- Amplifier
- Integrated
- Speaker System Details
- 1 x speaker 5 Watt - 100 - 18000 Hz
- Grey
- 9.86 cm x 9.86 cm x 10.65 cm
- 260 g
- 2 years warranty
- Product Type
- Speaker
- Enclosure Colour
- Grey
Speaker System
- Speaker Type
- Active
- 5 Watt
- Max Output Power
- 10 Watt
- 100 - 18000 Hz
- Nominal Impedance
- 10 kOhm
- Output Level (1m)
- 83 dB
- Amplifier
- Integrated
- Speakers Included
- 1 x speaker - 5 Watt - 100 - 18000 Hz - wired
- Driver Details
- Speaker: full-range driver - 2.24"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- AC power adaptor
- Power Source
- AC power adapter
- 9.86 cm
- 9.86 cm
- 10.65 cm
- 260 g
- Limited warranty - 2 years
