These 2.0 speakers deliver 10 watts of peak power and rich, clear stereo for great acoustics and a room-filling sound. The front panel has integrated volume and power controls with headphone plug-in and auxiliary input.
Rich stereo sound
10 Watts/5 Watts RMS Peak power delivers room-filling sound from the four-driver (two active, two passive) design. Enjoy clear stereo sound with enhanced bass -
Adjustable bass
Customize your listening experience. Add another dimension to your audio by adjusting the bass level with the tone control dial -
Simple controls
Easily access power, volume, bass, headphone jack and auxiliary jack on the right speaker
- Logitech Z200 - speakers
- Product Type
- Speakers
- System Components
- 2 speakers
- Speaker Type
- Active
- Audio System Max Output Power
- 10 Watt
- Amplifier
- Integrated
- Speaker System Details
- 2 x speaker
- Black
- 9 cm x 12.407 cm x 24.12 cm
- 1 kg
- 2 years warranty
- Product Type
- Speakers
- Enclosure Colour
- Black
Speaker System
- System Components
- 2 speakers
- Speaker Type
- Active
- Max (RMS) Output Power (Total)
- 10 Watt
- Amplifier
- Integrated
- Controls
- Tone, power on/off, volume
- Speakers Included
- 2 x speaker - wired
- Driver Details
- Speaker: 2 x full-range driver
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- Power adapter
- Power Source
- AC power adapter
- 9 cm
- 12.407 cm
- 24.12 cm
- 1 kg
- Limited warranty - 2 years
