Logitech Z130 PC Multimedia Laptop Speakers - 5 Watt
Speakers Z130
Quicklinx: 747ZWS00 Mfr#: 980-000419
Get rich stereo sound in a small package. Simple to set up and control, these speakers make it easy to enjoy your music, movies and games.
Rich stereo sound
With five watts of total power, you get sound that's clear and strong.
Easy to control
It's a snap to get the sound you want with simple volume and power controls.
Built-in headphone jack
Plug in your headphones and listen to your music, movies and games where and when you want to.
Simple setup
Just connect the speakers to your laptop with a standard 3.5 mm plug and you're ready to go.
  • Full Stereo Sound
    10W Peak/5W RMS power delivers clear stereo sound and strong bass
  • Strong Bass
    Front-facing reflex port provides extra bass to your audio experience
  • Easy Controls
    Easily access power, volume and headphone jack on the right speaker
  • Rich, clear sound
    5 watts of total power means you get strong stereo sound from these speakers
  • Easy setup
  • Your way
    A headphone jack and convenient volume controls let you listen to your music, movies and games on your terms
Logitech Z-130 - speakers - for PC
Speakers - for PC
United Kingdom
System Components
2 speakers
Speaker Type
Active
Continuous Power
5 Watt
Amplifier
Integrated
Speaker System Details
2 2.5 Watt
10.1 cm x 11 cm x 14.2 cm
0.59 kg
Speakers - for PC
United Kingdom
Speaker System
System Components
2 speakers
Speaker Type
Active
Continuous Power
5 Watt
Amplifier
Integrated
Controls
Volume
Speakers Included
2 - 2.5 Watt - wired
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
Audio cable, speaker cable kit, AC power adapter (UK plug)
Power Source
AC power adapter
10.1 cm
11 cm
14.2 cm
0.59 kg
