USB powered
Connect to a USB port for power and the 3.5mm input for audio. This compact design is simple to setup and easy to move around -
Cable Management
Adjust the length of the cords via the cable management solution on the back of the speakers -
Easy controls
Easily access power and volume from a single knob on the right speaker
- Logitech Z-120 - speakers - for portable use
- Product Type
- Speakers - for portable use
- System Components
- 2 speakers
- Speaker Type
- Active
- Nominal Output Power (Total)
- 1.2 Watt
- Amplifier
- Integrated
- Speaker System Details
- 2 0.6 Watt
- Power Options
- USB powered
- 2-year warranty
- Product Type
Speaker System
- System Components
- 2 speakers
- Speaker Type
- Active
- 1.2 Watt
- Amplifier
- Integrated
- Controls
- Power on/off, volume
- Speakers Included
- 2 - 0.6 Watt - wired
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , DC power input (4 PIN USB Type A)
- Power Source
- AC power adapter
- Options
- USB powered
- Limited warranty - 2 years
