Logitech Z 120 Notebook Speaker USB bla
CLEARANCE!
Clearance
Price Drop
Quicklinx: 83L9WS00 Mfr#: 980-000513#SP
These compact, versatile speakers are simple to connect and easy to control and enjoy.
  • USB powered
    Connect to a USB port for power and the 3.5mm input for audio. This compact design is simple to setup and easy to move around
  • Cable Management
    Adjust the length of the cords via the cable management solution on the back of the speakers
  • Easy controls
    Easily access power and volume from a single knob on the right speaker
Logitech Z-120 - speakers - for portable use
Speakers - for portable use
System Components
2 speakers
Speaker Type
Active
Nominal Output Power (Total)
1.2 Watt
Amplifier
Integrated
Speaker System Details
2 0.6 Watt
Power Options
USB powered
Speaker System
System Components
2 speakers
Speaker Type
Active
Audio System Continuous Power (Total)
1.2 Watt
Amplifier
Integrated
Controls
Power on/off, volume
Speakers Included
2 - 0.6 Watt - wired
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , DC power input (4 PIN USB Type A)
Power Source
AC power adapter
Options
USB powered
